This depends on where the hole is.
They make a bolt with two washers, the washers are cork backed, if you can reach both sides this is a fantastic drilled hole/puncture repair.
Option two has an oval washer on the bolt head end,, Now this is tricky but you can manuavure the oval through the hole, then position it and the round (larger) washer remains outside, Tighten the nut down and it's a one-side repair.. Been close to 50 years since I've seen em though.
Get a set of HORST miricle probes. The Ground (common) Probe can be put in the bottom o the tank if you like.. And will do what you want,, Bigger hole though I think.
Other ideas present as well, Can you drill the pipe about 1/2 inch above the valve? If you drill there you can simply put a sheet of rubber gasket material (Any auto store) and a hose clamp over it, or a pipe repair clamp (Home Improvement Stores) this might be your best choice.
GOOP works well for small things, Do not know how well it will work in this,, But I use it or sealing lots of holes in things.
