I found the leak in my roof. It is aluminum and there is what looks like rust holes. I taped over them with duct tape for now. It seems to be just the front right quadrant affected, the rest of the...
I have seen aluminum corrosion like that caused by contact with steel staples, any moisture will corrode the dis similar metals. I had a spot in mine do that, on a wall, I sanded, and filled the hole with JB weld epoxy.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
