albow's avatar
albow
Home dryer help needed
I came across a good deal on a washer dryer pair 2 years ago and bought them, letting them sit new and unused in my shed. Now that I need the dryer, I got it into the house but have run into issues I was unaware of. The biggest of these seems to be that I have a mobile home and the owners manual says I need different exhaust venting for this and also makes it sound like I need to pull air IN through a window for it, whether I use it in gas or electric mode. I had no idea it would do both and have gas at the house, but plan to use it electrically. It didn't even come with a power cord I just now noticed so I'll have to get one. Here is a quote from the installation manual. "This dryer is suitable for mobile home installations" blah blah standards, etc. "metal exhaust system hardware" must be used. "Special provisions must be made in mobile homes to introduce outside air into the dryer. The opening (such as a nearby window) should be twice as large as the dryer exhaust opening."
What exactly does this mean? There is a window in the room, which is actually part of an outside door. It doesn't mention putting a vent from the window into the dryer. Are they talking about for emergency ventilation of the room or something? I mean, neither the original dryer nor the second one, which was installed by Lowes I believe, have had anything special that I am aware of. You would think if some special venting were needed that the laundry room would be made to conform from the get go. As well, I haven't had metal exhaust pipe. I've had the flexible aluminum foil type the whole time and apparently Lowe's didn't care when they set it up. Convince me that I need to do something different rather than buy a cord and wire it in. What's the deal here? I guess there's a safety standard that has changed through the years? I know there are different venting requirements for gas appliances such as water heaters in mobile homes but this will be electric. What do I need to do?
  • You can't operate a dryer in a closed room with a closed door. The dryer functions by moving hot moist air out the vent and outdoors. The room can create a vacuum and reduce airflow. Usually it is a 4" round exhaust vent so 25 square inches of window opening to allow air into the room. Not meant to be complex.
  • It sounds like they think it needs a window open to some extent to provide an adequate air flow thru the dryer to prevent overheating. A window due to the typically small internal volume of an RV. An RV is not exactly air tight, but still small compared to a house. Must really be some significant air flow.
  • What Brand and Model Dryer? I have never heard of a DUAL Gas/Electric dryer. Doug
  • GAS Dryers require solid Metal (not flexible silver foil type) exhaust tubes, due to the HEAT a Gas burner puts out. 120/240 dryers also request same venting but you can get by with standard accordion type dryer hoses. The air venting is to make sure you have enough intake air INSIDE the home to keep from exhausting the air inside the dwelling and have enough volume of air for the usage of the Dryer Gas Burner. Since it specifies Mobile Home, there must be a history of Mobile homes being more airtight than standard stick homes. Doug
  • With all the warnings, I believe you should let a professional install the dryer.
  • I would think special venting and exhaust would be necessary only for gas operation. Electrical operation should not need any thing special to be done, same as any standard electric dryer.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
