LittleBill
Mar 16, 2014Explorer
eb145 wrote:
The little voltage boosters are designed for laptop power supplies that can plug into 12V cigar lighter outlets in cars. They are designed as constant voltage output (variable voltage). With no apparent limit to the current. They will burn out quickly if allowed to pass lots of current - thus the fan to cool them in the summertime. Max power is 150W per device.
Ed
Not really sure what you mean by there is no limit to current . right in the listing it says 6 amp. of course they have no limit but you better push some serious airflow if you expect them to last
" DC-DC 150W Boost Converter 6A 10-32V to 12-35V Step-Up Voltage Power Supply"
fan would do alot better also if you actually had it aimed over the heatsinks
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
