MFL's avatar
MFL
Nomad II
May 10, 2014
Home plug-in options?
When my 30 amp FW is at home, I have two electrical options. I can plug in close with a 25' 12 ga cord, into a 15 amp circuit.
I also have a 30amp circuit, just for a rarely used air comp. It would require a 50' 12 ga cord to reach.
I have a 30 to 15 amp 6" dogbone, that I use to hookup.
My question is, will I get much more amperage from the further away 30 amp circuit, than the closer 15 amp, since I still need the 30-15 dog bone to hook up?
Will I only get 15 amps no matter what, since the dogbone is reducing to 15 amps?
I would appeciate any help or thoughts.
Jerry
  • The electrician made an error when he used 12 AWG wire and a duplex outlet for a 30amp circuit. 30 amps requires 10 AWG wire minimum for a 30 amp circuit.
    Here are the wiring requirements:
    15amp - 14 AWG
    20amp - 12 AWG
    30amp - 10 AWG
    Also, a 30 amp circuit requires a different receptacle compared to your normal 15/20 amp duplex receptacle.
    If it were me, I'd connect a new 30amp breaker, 10 AWG wire and dedicated 30amp outlet for the RV, and I'd replace the 12 AWG wire and duplex outlet for the compresser.
  • The 30 amp circuit is 110/120. It is a 30 amp breaker in my home entrance, that is wired just a short distance to my compressor, with a normal 2 outlet plug in.
    The electrician just used a 12 ga wire to the outlet, about 10 feet.
    Is there a heavier dogbone that I could buy, such as 30-30 or 30-20? I have only seen the 30-15.
    I normally just plug in for charging the battery, and using the fridge on electric, when getting ready to go camping, otherwise I'd consider putting in a proper RV outlet.
    Thanks for your reply pianotuna!
    Jerry
  • Hi Jerry,
    The dogbone won't reduce the amperage--but it is probably rated for 15 amps. If you use it for more than a short time at a 30 amp draw it may melt.
    A #12 cord is limited to 20 amps.
    Are you certain the 30 amp circuit is 110 volts?
    If so, make up a #10 cord and perhaps add a proper 30 amp outlet to the air compressor.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
