NinerBikes
Jun 07, 2014Explorer
like2rok wrote:
When i start it cold, then go to Eco Mode On, then RPM's are slightly higher than when it warms up and slows down even more. It IS Much Slower than Eco Off which wastes fuel overnight when the AC only needs to run a few minutes per hour. On this thread Please Refrain from suggesting the easy fix of Eco Off.
The entire purpose of spending $1000+ on this Inverter Generator is the Fuel Economy/quiet operation and I refuse to settle with Eco Off as a solution.
I will keep this thread updated on the attempts to modify eco idle speed or rejetting.
FYI I have the Whynter GREEN ARC-110WD AC with dual hoses that specs state 9.5amps maximum current
Spend 2000, and buy a second Eu2000i to run in Eco on position, and pair them. Your A/C will have no problems running both in eco off position.
Read the Honda information on their website. They recommend either a 3000 or a pair of 2000's for A/Cs over 9000 BTU. Start up load is too great for a single EU2000i.
You've under engineered your generator supply in amps, plain and simple.
You're running a motor at very heavy loads with just one, in very hot air that is far from being very dense. Since the air is not dense, it can not take on much fuel to burn with it in the engine, which is in essence a pump. Every heard of cold air intake? Or intercoolers?
Maximum current is once the unit is in full operation. It does not take into account start up current, which is easily double that, about 20 amps. Since your generator can make 1600 watts, 13.3 amps, max of 2000 watts, you're short on beans to start your A/C unit. You are also doing a diservice to one generator running it that hard all the time percentage of load wise, running that A/C day in and day out. Spend the money and pair a set of Eu2000i's to do it right.
You refused to do the load calculations, and you came up short. The rotor lock load at start up on your A/C exceeds the design limitations of your Eu2000i.
Honda wattage calculator
