time2roll
Jul 24, 2016Nomad
You will not be able to use a grid tie solar inverter afaik. They really need to dump 100% of power to the grid.
What you can do is use an inverter with assist to combine power with the Honda. Inverter can be set to draw limited power from the generator and the rest would be supplied by the battery-solar.
I assume you are well above 500 watts solar to make this worth while.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
