Does anyone know if you will get any 120VAC POWER out of the companion twist lock connector if the generator is running by itself. I know you will get 120VAC @26.6AMPS if you have two generators connected together. Since I don't own the companion I don't know if you get any power at all from the 26.6AMP Receptacle.
The OP states he might want to get the companion first because of this 26.6 AMPS receptacle and I am thinking it will be a completely dead receptacle unless you have two generators connected together.
In other words you will not get 120VAC @ 13.3AMPS out of this twist lock connector using the companion generator by itself.
I may be wrong with this statement - just don't know.
The OP might want to know this before making his decision on which one to buy first. If it is a dead twist lock connector then you will only have one 120VAC 13.3AMP receptacle that you can use on the front panel of the companion generator.
Was hoping a companion owner on here would answer this question...
Roy Ken
