rbp111 wrote:
A side issue. Why does Honda not put a rv receptacle in the Companion model? It would seem to me that RV people buy a significant number of Companion models. It would seem simple enough, you have a choice of the rv model or the contractors model.
well, first RV may not the primary use of honda 2000's. I know way more folks doing construction using the honda 2000 than I do amongst quite a few RV friends. Second, ever try to find a RV to twist lock adapter?? scarce as hens teeth. 30A construction equipment uses the twist lock. Twist lock to RV is much easier to find.
I suspect most honda dealers would not like to have to carry an addtional model to have one with twist lock and one with RV
