rickhise
Jul 08, 2019Explorer
RAS43 wrote:NRALIFR wrote:
Make it easy on yourself and measure out the correct quantity of oil (yours is about 13.5 oz), tip the generator on it’s side and use a long neck funnel to pour it in. Put the cap on and don’t bother checking the level against the filler hole.
Your generator has a low oil level warning system on it that will shut the engine down before it reaches an unsafe level.
This!!
Ditto use a dawn dish soap bottle put a piece of duct tape even with 13.5 ounce level
funnel. I stuff a few paper towels inside the filler an case tip it over and let it drain in a towel on a flat baking dish
No need to check the level
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
