C_Schomer
Oct 10, 2022Explorer
I found my bonded connector in the basement today and it is the 15 amp male to Rv 30 amp female connector but I made this connector several years ago and my CRS is too bad to remember why!
The thermostat and furnace did nothing when connected to the generator so the generator didn’t need to do anything either.
I cut my teeth on oil burners and stack safety controls, and then on to RA 890s, Purple Peepers, Fire-eyes, 1/2 wave flame rectification,micro amp measuring, oil-free magnetic bearing compressor and everything else the HVAC and industrial process control manufactures could come up with… until I retired in 2015, anyway.
ECM motors are awesome… The incredibly strong permanent magnets make them so efficient and they ARE inherently soft start. I’m not worried about the in rush current.
My generator is at home and I don’t remember the exact model but I know it is a 2000 and it must be inverter because it has a switch to enable it to run at only the rpm necessary. It also has a duplex 15 amp receptacle and no 30 amp RV so I know it only generates one phase.
Gdetrailer, thanks also for the tip to do the bonding inside the generator… I will probably do that instead of making another bonded connector. Then if the furnace runs on the generator I will make my own transfer switch.
I will return… in January!
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
