Bobbo
Dec 08, 2022Explorer II
C Schomer wrote:
Well, there wasn't much room under the cover to do the bonding. My Honda 2000 has a 15/20A duplex, so I used 12 ga. wire for the bond. The simplest way would be to make a short connector... 120v/15A plug to 120v/15A cord receptacle, and use 12 ga. wire to support inrush current, and bond it on whichever end you want. Once that's plugged into the Honda, the other side of the duplex will also be bonded and you can use the bonded connector, as well, to plug something into. Just use the bonded connector, first, if you need the bond for whatever you are running. It only needs to be bonded at one point, internally or externally, and the connector cord WON'T eliminate half of the duplex, like a bonded plug would. Craig
Or, just bond the back of the duplex outlet built into the Honda, like I did. No additional hardware need be carried, no outlets are taken up. If I recall, that is exactly what the OP finally ended up doing.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
