LittleBill
Nov 12, 2018Explorer
more then likely the fuel passage that shuts off from the float valve is clogged and not letting the valve close, remove the valve and blow compressed air up the inlet line, make sure the main gas line from the tank is removed or the gas cap, otherwise it will spit it back at you with pressure once your done
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
