- Me_AgainExplorer III
NinerBikes wrote:
Following up, did the low oil sensor being replaced fix the oil leak?
Have not done that at this point! Do you have a similar problem?
Chris - NinerBikesExplorerFollowing up, did the low oil sensor being replaced fix the oil leak?
- Me_AgainExplorer IIIWell, I bought a crank seal and took it was apart again. Crank seal area was clean and dry as a bone. So must be the low oil sensor on the bottom of the crank case.
Chris - Me_AgainExplorer IIIOnly plastic cases have ever been off it. Carb cleaned a few times. It early model that we have had for years. I will recheck cc vent. I think it is the crank seal, as end was the only wet area. I suppose the case has to be split to change the shaft seal? Chris
- azrvingExplorerNot over filled? Has it had recent work and possibly reassembled incorrectly. I've seen small engines with air filter housing/crankcase vents not breathing correctly resulting in excessive crankcase pressure. It will push oil of of crank seals and even seen it push oil past crankcase cover gaskets.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
