- v10superdutyExplorer
Woden wrote:
Anyone have any tips/insight into this issue i'm having with my generator...new generator, cannot pull starter cord , seems stuck, can't imagine the piston is seized. Has oil in engine.
Any chance you can update us? :h - v10superdutyExplorer
dclark1946 wrote:
v10superduty wrote:
RJsfishin wrote:
Its just so hard to believe the weird stuff I read here,....no other comment.
Yup.. :h
:B
I would not have believed it myself except I experienced it first hand.
Its not possible Dick.
The atmospheric pressure is actually lower in Colorado so bringing it to a lower elevation would actually "help" turn it over when you pull cord.
However this pressure would equalize pretty quickly. The time to ship it to your house would eliminate this as a cause.
I think what may have happened is this seller has a device where he can remotely unlock these Hondas once he knows payment has cleared. :B
When you called him, it triggered him to hit the unlock button.
Just kiddin ya ...
but what you experienced is an anomaly for sure. :h - dclark1946Explorer
v10superduty wrote:
Yup.. :h
:B
I would not have believed it myself except I experienced it first hand. - RJsfishinExplorerWhew!! Glad you cleared that up.
Think we mite have a couple troller here ??
That TDC thing was perdy good, but that mountain elevation air thing can't be beat ! :) - v10superdutyExplorer
Lynnmor wrote:
So, did you pull the spark plug and try it? Was the last two posts helpful?
Maybe this will be helpful?
Its not stuck because piston is at top or bottom dead centre.
Its not locked cause its got some high pressure mountain air in it.
Its locked because its got rust or something seizing it.
Or... its hydraulically locked (was mentioned)
Or... something has come apart, possibly in rewind starter and jamming it.
To OP, good luck.
:h - LynnmorExplorer IISo, did you pull the spark plug and try it? Was the last two posts helpful?
Yup.. :h
:B - RJsfishinExplorerIts just so hard to believe the weird stuff I read here,....no other comment.
- dclark1946ExplorerI had a similar problem with an EU 1000 I bought on Ebay. I called the seller to tell him he had sold me a defective generator that was locked up and I could not pull the starter rope. He said it had to do with the altitude difference between Colorado and Texas and said to try it again the next day after pressures have equalized. I thought to myself I am not buying that explanation. The next day I tried to pull the starting rope and it worked perfectly.
- road-runnerExplorer III
If the piston is spot on Top or Bottom Dead Center (where it briefly stops going Up or Down before changing over to Down or Up, it can be very hard to pull the engine over.
My logic thinks just the opposite. With the piston at TDC or BDC, the crank can turn with little or no resistance from the piston, and has maximum leverage to move it.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
