mtofell1
Jul 22, 2019Explorer
I finally got around to digging into this and I think it turns out the carb was just loose. I was really just trying to refresh my memory about where it was leaking so I pulled the carb off to see how the parts went together. When I put it back together no more leaking! I had been on some REALLY bumpy roads right before it started leaking so maybe it just worked it's way loose. In any case, if anyone finds this thread with a similar problem, try just removing the carb, check the gasket and tighten in back up. You just may get lucky like me.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
