BFL13
Nov 27, 2019Explorer II
EDIT--ran a test on low amp output--results after this
Trying to follow Mr Wiz's example where it says 123.3 x 2.14 = 263.9VA
and then shows 170 Watts. So that would be 0.64PF like he says.
BUT--output is 49.6w (14.56 x 3.4) so at 85% efficiency, the input would be about 58 watts for the converter.
What else is on that gets that 170 watts vs 58?
Looks like Mr Wiz is on to something (of course!) :)
Using the 75 amper, Kill-A-Watt, and Trimetric, unplugged shore power and have only converter on the P2200. Started with about 4 amps DC load on full batts, then about 13 amps, then about 24 amps.
(P2200 unloaded--125.4 volts)
124.7v, 1.17a, 82.6w, 139VA, PF 0.57, output 54.4w
123.3v, 3.70a, 268w, 413VA, PF 0.61, output 174w
122.0v, 6.45a, 455w, 696VA, PF 0.63, output 322w
So efficiencies were: 66% (54/83), 65%, 71% (322/455)
This seems to confirm Mr Wiz's observation that the converter is more efficient at higher amps. That might be from having a sort of internal fixed load to it so as output amps are higher, the internal fixed load is less in proportion?
Even so, I got 54 vs 83 (66%) where he got 58 vs 170 (34%) so it still seems he had some other draw besides the converter, but as he also said , there are many possible factors.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
