reno6's avatar
reno6
Honda 2200i and 15k AC
I think the planets of Jupiter, Mars, and Saturn were aligned just perfectly or I am just incredibly lucky.
2018 Keystone Bullet with 15k Dometic AC and I installed an older SPP6E capacitor that I had laying around from a previous trailer. Just a simple 2 wire install taking about 10 min. Took the 2200i off eco mode, turned off all breaker in the trailer except the 20 amp AC so as to limit the load on the generator.
Set the AC fan on low for a few minutes, then slowly started to drop the temp on the thermostat waiting to see what would happen. Boom! AC fired right up with the generator slowing down just for a second. Ran it for over an hour. After the AC was running for a few minutes, I put the generator on eco mode and it actually dropped several hundred rpm so that tells me it is not maxed out.
For those of you who want to pick apart my success, I am at 4800 feet at 89 deg F outside temp. Throughout the day, I repeated this process 4-5 times and it worked 100% every time. Either the 2200i puts out more than advertised or my AC is a mislabeled 11k unit(not likely). Either way, I am incredibly happy!!!
