TECMike's avatar
TECMike
Honda 3000 Problem
Our 12 year old reliable, trouble free, Honda 3000 generator has started to give me and my wife a problem.
It has always powered our Dometic 13,500 AC unit fine when boondocking, but now shuts down a few minutes run time after the AC compressor starts.
Our AC unit runs fine when plugged into house or campground current.
We sure would appreciate some comments or suggestions as to what may be the problem with our Honda 3000.
Thanks in advance!
Mike
  • A voltage/amp meter will tell you alot with what's going on.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    This may sound strange but have you Cleaned the Air Conditioner?
    As they run. Most makes (Coleman is a partial exception) Crud builds up on the fan side of the condenser. as this builds up air flow is impeaded. as air flow is impeaded the unit heats up more and more. Pressure in the system increases. The compressor works harder and draws more power.. The CLUE is the "A few minutes".
    The solution: remove outer cover (Shroud) and inner cover (on evap) clean the fan side.
    On colemans they "SUCK" instead of "Blow" so the crud builds up on the OUTSIDE of the condeser. Remove cover. peal off. replace cover done.
  • Check the voltage at or near the AC, if it is low then check at the generator to see if the loss is the wiring or the generator.
    If you mean the generator shuts down, maybe the increased use of fuel when the AC is running causes the generator to overheat or the tank vent is not open.
  • Have you cleaned the spark arrester in the muffler?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
