mikestock
May 13, 2013Explorer
BFL13 wrote:
I wonder what this "yellow adapter" is that everyone has
That's just a small adapter that plugs into the 23.3 amp twist lock receptacle seen in one of the above pictures. The standard three prong RV pigtail plugs into it.
To the OP: You can try using the companion cables, pairing the EU3000is with the EU2000i (not the companion). Draw from the 30 amp receptacle on your 3000. They will pair up just like the two 2000's. I've done it many times to run two ac's. This may give you enough juice. That's a total of 4200 watts or 35 amps.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
