N8GS's avatar
N8GS
Honda and onboard PSW inverter?
Many inverter generators will sync up and run in parallel. As I understand it you start the first generator and then the second one sync's to it when started. My question is - could this work with an onboard 2000 watt PSW inverter and a 2000 watt Honda generator. I'm thinking that if it is possible it would work well for load sharing when starting the AC, eliminating the need for a second generator.
Has anyone tried this? Did it work or did it let the smoke out.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
