- j-dExplorer IIIf the piston is spot on Top or Bottom Dead Center (where it briefly stops going Up or Down before changing over to Down or Up, it can be very hard to pull the engine over. Ironically, I'd venture, if it's a new, tight, engine.
Can you get at the flywheel at all? And just give it a little nudge? - Big_BruceExplorerDo not let plug wire short when turning over motor in case it is flooded with fuel.
- LynnmorExplorerPull the spark plug and try pulling the cord. It may be flooded with gas or oil. Do this outside.
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
