Huntindog wrote:
Umm I agree. You just took a lot more words to say what I did.
Ok. I guess I missed something then. Your original quote:
Huntindog wrote:
banana plug cords tapped in before the 20 amp breaker will allow for higher output. Correct?
is what I don't agree with. Where you tap in to parallel them has nothing to do with the output. Actually it does affect how much you can access, but you would get higher output with the suicide cord than you would with the banana plug cord. If you suicide connected the 2 with the top receptacle on each, then plugged into the bottom receptacle on one, you could pull 26A from that bottom one. 13A from that generator and 13A from the other, through the top to bottom of the receptacle. Not that I would do that as it would be dangerous and overloading the receptacle.
So long as we agree, I guess we're good. Even if we don't, we're still good. :)
