marc71 wrote:
I'd sure hate to ruin $2200 worth of equipment.
2oldman wrote:
I thought about that before making my own parallel cables.. but they've been no problem at all. Honda makes it sound like that's a big no-no, but so far it's a yes-yes.
The fellow you referred to running the 3 Hondas.. did he make his own cables?
marc71 wrote:
Yes he did make his own cables... he spoke with someone at Honda before doing so and they told him it was a no no to do this.. it's been working for years
Custom Honda parallel cables are designed to avoid the potential of shock if one set of ends isn't always connected to the second genset whereas a suicide cord not connected at one end will expose one to the potential for shock. Electrically the only difference in simply paralleling the output receptacles of the 2 gensets yourself using a suicide cord instead of using the custom Honda cables is the custom cables connect directly to the inverter output
before the 20 amp circuit protector rather than
after it. Obviously, the phrase SUICIDE CORD is used for a reason. :W
