bigfootford's avatar
bigfootford
Nomad III
Dec 30, 2021
Honda Eu2000 valve job/repair
Watched this video for fun and enjoyed it. Think some of you will too. Guy has the skills to do a full teardown and re-assembly and no left over parts and the **** thing runs.
I have performed a partial teardown for a repair and getting the covers/skins back on correctly is sometimes not so easy..hahahaa
Honda EU2000i repair.
Jim
  • 2112's avatar
    2112
    Explorer II
    Durb wrote:
    My take away: Why spend $240 for an old broken generator that you don't know you can repair? Then, put in all that labor with the possibility of needing expensive parts. Why not spend $500 on a different brand and get a brand new generator?
    Considering his knowledge and tools on hand it wouldn't be unreasonable to conclude this is his livelihood. He would know a replacement inverter module retails for $700. The stator is $150. Many other donor parts as well.
    I have an EU200i and enjoyed seeing the complexity that is under the covers.
    Maybe it was a challenge for the young man and curious....
    That all said it does make me wonder why so much carbon. As he took apart the Gen it was quite filthy internally, dirt and dust etc. I believe the gen had a lot of hours on it.
  • My take away: Why spend $240 for an old broken generator that you don't know you can repair? Then, put in all that labor with the possibility of needing expensive parts. Why not spend $500 on a different brand and get a brand new generator?
  • 2112's avatar
    2112
    Explorer II
    Sitting here thinking about this video over my morning coffee I had to ask why a 6 yr old generator had so much carbon build-up to begin with. I concluded it ran cheap gas at idle on a job site for long periods of time. My guess is the owner never put much load on it and allowed it to idle on eco mode all day.
    The real take away on this is to occasionally load up your generator to keep if healthy.
  • 2112's avatar
    2112
    Explorer II
    Very informative.
    I wonder if a good ATF soak for a few days would have helped? I would have tried that after the leakdown and realized the head wasn't removable.
