Gdetrailer
Mar 13, 2021Explorer III
Generally, as long as you do not damage or tear the gaskets, you can usually reuse them multiple times before needing to replace.
Looks like gasket kit is running $13 and new generic replacement carbs are starting at $37.
HERE
Might be a real toss on that one to outfit one carb with high altitude jet.. That carb looks like it is a bit of a challenge to replace with the stepper motor and hoses.. Not a simple change out..
The jet should be accessible just by dropping the fuel bowl which depending on how much room you have may be easier to just swap jets than the entire carb..
But if you really want to change carbs, I have had good success with lower priced aftermarket carbs on B&S and Tecumseh engines..
HERE
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
