smcrea wrote:
ford truck guy wrote:
I have a single 5 gallon extended run tank with a Y connector feeding both my Honda's and love it... Never thought about the 2 tanks.... Double the run time.. I like that idea...
Could you tell me where you got the parts for both gen sets with Y connector into the single tank?
Thanks!
If you are going to run like this, don't forget to change the motor oil regularly. 10 to 15 gallons of fuel run per engine, between oil changes. Motor only holds about 1/2 a quart of motor oil, that's a lot of burnt gas residue in a little amount of motor oil for an air cooled engine. Again, air cooled, not water cooled, is tough on all motor oil. Oil has to carry away a lot more heat on an air cooled motor, so change your oil frequently.
