I also run Mobil 1 synth oil and premium, non-ethanol SeaFoam treated gas in my EU2000i and it starts first pull, every time. :B However, there is a trick I read on the forums some time ago by robert_at_honda ...
1) Open the full cap to verify the gas level
2) Close the gas cap and turn the vent lever to the closed position
3) Turn the choke on full, turn the main switch to ON, then let it sit like this for at least a minute
4) After an minute or so, open the fuel cap vent and start the engine
My understanding is this process allows fuel pressure to build so when you do start the engine it will start right away ... mine does. :B
