copplecrown
Feb 06, 2018Explorer
Mine is an EACT-###### also, and was acting the same. I did find a place locally that sells ethanol free gasoline, mostly for the boating crowd, but it's so expensive most people don't buy it. As a result, I had concerns the fuel was old when you bought it.
The source I used for parts is boats.net. You may not be able to check the gears on the idle control motor, other than spinning the shaft to see if it moves freely and smoothly, with some resistance.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
