Thach2264
Sep 22, 2013Explorer
Oil is filled to the top and fresh gas. I just found an electrical schematic online. I will do another test to confirm.
With the connector connected, I get 1s of spark and then no more which at the same time the oil alert LED flash/blinks. With the connector disconnected, there NO spark at all.
With the schematic, I noticed that the yelllow wire is for the oil alert and the black wire is the ground for the spark plug. No wonder I get no spark when disconnected the connector, I disconnected the spark plug ground.
I'll try to just disconnect just the yellow(oil alert) on the engine side, not the connector near the batt.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
