Thach2264
Sep 23, 2013Explorer
Well today after looking at the eletrical diagram, I though it would start. But-nogo. I disconnected the yellow wire on the engine side with the black still connected. Same result ie. get 1s of spark, then no more as oil laert LED flash/blink.
I measue V from the yellow wire connected and disconnected to 12V batt both reading around 0.6V. The yellow wire is not ground for sure, it just floating. When the generator is running, what's voltage reading on the yellow wire??? 12V???
Measure resistance on the engine side to ground = open.
thanks.
thanks.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
