RoyB
Apr 03, 2014Explorer III
FIXYA ON-LINE says:
BROKEN PULL CORD EU3000i
"The only way to get to the starter on a EU3000IS is from the front of the machine .
You have to remove the plastic around the control panel , remove the control panel and the inverter and you be able to see the starter on the right side . To remove it is only 3 10mm bolts holding it in place . Make sure when you put it back is on the right place and pull the cord gently so the starter can sit .
Hope this help"
There are alot of VIDEO's ON-LINE on how to repair things with the Honda Generators...
Roy Ken
Hope this help"
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
