Thach2264
Sep 25, 2013Explorer
I did try spraying starting fluid to the carb throat, but no go.
I was doing continuity test on the stop/start key switch and this is what I found. At first I though I have a bad key switch, because at on the black and green is 0ohm (key to on). After isolating all the connector, I found that my black wire for the ignition coil is grounded.
http://www.amazon.com/Honda-EU3000-EU3000is-Generator-Service/dp/B00D2404S4
How can that be bad? can that be repair or clean?
As posted above I do get spark BUT for about 1s, before the oil alert LED flash/blink then no more spark.
