horton333
Jul 03, 2017Explorer
Airh22 wrote:
I have a Honda EX1000. It does not I’ll put enough voltage at idle around 8.5 V. If you manually increase the RPMs the voltage will read properly. Anytime I Plug Something in it Will Not Automatically Increase The RPM to supply Enough voltage. Not sure what this could be any suggestions?
The 2k units say in the manual that the 12volts is only to be used with ecomode off, ie full throttle. May be the same for the 1k units...
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
