wa8yxm
Feb 20, 2014Explorer III
For RV use the Companion as the first generator you buy.. REASONS.
First, on the companion they have a genuine 30 amp outlet.. Not sure if it is TT or Twist Lock but it's 30 amp.
Second, if you later get another (Either a companion or not) you use a less expensive set of cables to parallel.
Finally, They did not put the useless 12 volt jack on the companion so you won't be asking questions about it or trying to use it and winding up doing mroe harm than good.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
