TNRIVERSIDE
12 years agoExplorer
Thanks to all for the input. After reading all the information I went with the companion. The 30 amp receptacle does work in the sole mode. Both are protected by the breaker. The 30 amp twist lock will work well when used at home in the wiring configuration that I am using. And if I do need to use two units it will be easy to add the second unit.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: 6 hours ago
