Horizon170
Feb 22, 2014Explorer
I'm not sure if I did the right thing. Your opinions will be appreciated. Since I use my Honda 2000 to run my 7200 BTU A/C I made this adapter with the thought that it would allow the plug ins to run cooler and not over heat . I just paralleled both of the duplex outlets into one 30 amp and plug my 30 amp into it. That 30 amp runs from the front of RV, where the 2000ie is anchored to a Transfer switch. My regular shore line is separate. This way I can run the Generator while traveling.
">Picture 1
">Picture 2
When making it I plugged both male into a dummy receptacle and used JB Weld and a spacer plus tie straps to hold in place. Perfect fit and it is cool.
">Picture 1
">Picture 2When making it I plugged both male into a dummy receptacle and used JB Weld and a spacer plus tie straps to hold in place. Perfect fit and it is cool.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
