PNW_Steve
Jul 23, 2019Explorer
opnspaces wrote:
Does the 3000i have an eco mode? if so do the RPM's increases if your turn the mode off?
Maybe try pulling the carburetor off and manually move the the throttle butterfly with your finger then reassemble. On my 2000i I had a problem where the stepper was stuck after cleaning the carb and I had to move the butterfly give it a bit of help to get it going again.
I would also check or replace the spark plug as there could be a problem with it and they're cheap.
Yes it has eco mode. It does not make any difference.
I will try exercising the butterfly.
