If you are never looking to run ac then i would say go with the Honda 1000. If you think you may use it for other things in the trailer i would go with a 2000. Now if think its possible you will use the ac then you either need the 3000 or two 2000. Those are the general guide lines. I would go little over with the 2000 going by your description. Good luck hope i helped.
