MKDSK
Jul 16, 2014Explorer
Honda Generator
What Honda generator is the best one to get for my travel trailer? I would really only be using it to charge my batteries every other day.
Wayne Dohnal wrote:
I totally disagree with this explanation. For each generator, as its power output goes up its output voltage goes down. This causes the load to be shared based on the capability of the generator, not the absolute power level. With perfectly calibrated inverters each generator's output voltage will be the same at rated power, meaning each one will supply its rated power without the other one overloading. From user reports we know that the inverters do vary in their load-voltage curve, and even the equal-size generators don't always share the load equally. This applies just as much to matched generators as to different size generators. A Honda inverter generator has no knowledge of what the source of the parallel power is. As long as the load-voltage curve of the parallel source is compatible (and the frequency is correct), the generator is "happy".
