eldel's avatar
eldel
Hooking up 30A at home
I'd really like to be able to run the AC on my rig when I've got it parked outside the house before we take off on a trip. The 110V house supply isn't enough but I do have a 220V / 30A outlet in the garage which is a 14-30 outlet.
I'm looking and reading but I don't see anywhere where I can get a 14-30 to TT-30 converter. 14-50 to TT-30 yes. Is this even possible (assuming that the 14-50 converter just splits 220/50 into 2 x 110/25) or am I looking at wiring in a new circuit?
  • I did 30 amp at my house. Home Depot had the RV 30amp plug receptacle and I used 10 gauge wire, as I recall.
  • theoldwizard1 wrote:
    eldel wrote:
    I'm looking and reading but I don't see anywhere where I can get a 14-30 to TT-30 converter (adapter).
    NEMA 14-30 to TT30
    or it you want one with a pigtail
    NEMA 14-30 to TT30
    Those are generator adapters that twist lock. I assume the OP needs a straight blade 14-30P.
    I would get a 30-TT pigtail and wire it to a Hubble 14-30 plug.
    One hot of the plug will not be connected.
    For a longer cord get a 30 amp RV extension and cut the male connector off.
Having RV issues? Connect with others who have been in your shoes.24,287 PostsLatest Activity: Jul 23, 2025
