swimmer_spe's avatar
swimmer_spe
hooking up a second battery
I plan to go camping for a weekend, but may not have power. I was thinking of bringing a spare battery and swapping it out. I also thought of just running jumper cables to the 'dead' battery. Would doing that work, or must I swap it out? I don't want to mess with daisy chaining it.
  • wopachop wrote:
    Be careful if the spare battery is from an automobile. A car battery is not meant to be run down like a trailer battery.
    Maybe everyone can chip in and rent a genny?
    It's another deep cell battery. Where I am going doesn't allow generators or I'd be doing that. I have access to several.
  • CA Traveler wrote:
    Swapping is best. You can remove the negative battery cable and connect the jumper cables to it and the positive post.
    Daisy chaining to me means serial - definitely don't.
    I'd still do it parallel.
  • Be careful if the spare battery is from an automobile. A car battery is not meant to be run down like a trailer battery.
  • Swapping is best. You can remove the negative battery cable and connect the jumper cables to it and the positive post.
  • Swap it. Never connect a good battery to a dead one. It'll try to suck the good one dry.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
