Mdmheath's avatar
Mdmheath
Hooking up a UK RV in USA
I'm shipping my Autocruise Jazz RV from UK to USA for a 6 month holiday in 2015.
In UK I hook up using a standard cable used across Europe for 220 or 240V.
Can I get a cable or an adaptor that will allow me to hook up my UK RV to a 110V USA RV site post? If so, will my 12V lights work OK?
Secondly, can it get a gas bottle and adaptor pipe for my gas supply? In UK I use 6 kg propane bottles.
Looking forward to my trip !
Mick
  • Air conditioner and microwave may not like the 60Hz vs your 50Hz.
    Many campgrounds have what we commonly call 50 amp service that runs at 240 volts. You can probably make an adapter to match the outlet to your cord. It is a NEMA 14-50 designated outlet. Most common is the 30amp that is 120 volts 30 amps and would need a transformer to step up voltage but that does not change the cycles.
    Otherwise if you can get by running off your 12v battery we have plenty of ways to keep the battery charged.
    I don't know the technicalities on propane but a dealer should be able to set you up with new hose and fitting as needed. Or set you up with a US bottle and adapter.
  • Most RV parks have 50 amp hook-ups. For the experts: Couldn't the OP simply rewire a 50 amp plug/pigtail for 220-240 volts?
  • You could start looking here for your electric needs. When I was stationed in Europe I used several indoor transformers to run my 110v appliances from a 220v outlet. They worked great as long as I didn't exceed the rated watts.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
