Housted
Jul 16, 2023Explorer III
wa8yxm wrote:Housted wrote:
Just another reason to convert your gas/electric absorbtion refer to 12 volt compressors. The outside vents remain in place and the heat is sent outside. Convection moves air from the side vent to the roof vent.
Fans move air when the compressor is running. No heat to the inside of coach. :)
Housted
But what if you order it with the all electric.. And at 20 amps That's a heavy chomper of battery power.. a Good Compressor unit needs less than 1/4 that kind of power.
Sorry there are no available 12 volt compressor friges that only draw 5 amps!!! My conversion only draws 14 amps when both compressors are running. They rarely run at the same time.
They are separately controlled for the refer and freezer.
Houated
