Alright, so after replacing my batteries I thought that our problems were solved. Especially when we arrived after two weeks to fully charged batteries in the storage yard(The refrigerator was hot how...
to me it sounds like your NEG-ground connection is NOT grounded at the frame, the wire is broke, or the fram connection corroded
when you put the meter directly between negative and frame ground you supply a clean good path yes 10 amps is high for parasitic loads could be a bad control board on the fridge, or something else
fix your neg to frame ground then track down you load i would pull the DC fuse for the fridge for a starter then the rest
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
