Alright, so after replacing my batteries I thought that our problems were solved. Especially when we arrived after two weeks to fully charged batteries in the storage yard(The refrigerator was hot how...
Sorry to hear you are having issues! If you don't mind I will jump in for my 2 Cents. :) Voltage and Amperage are two different things and almost all VOM can only read Voltage and Ohms. To read Amps AC or DC requires a Clamp on type of meter that will clamp around a wire you want to test for Amperage (Load).
I was not to sure from the post if this was how you were testing your Amp Load.
There is a lot of good advise on hear and I am sure you will get to the bottom of your issue.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
