wa8yxm
Jun 25, 2017Explorer III
time2roll wrote:
I thought the top coils were the hottest? If the fridge is working I call normal.
Second: Even on electric.. Believe it or not this fridge (Absorption cooling unit is the formal name) runs on HEAT, Yes it has heaters in it.
How it works
Heat, be it from a propane burner or an electric heat element, causes some chemicals to seperate. they then travel via different paths through the outside heat exchanger giving off heat, then they come together again inside the Cold box.. When they come together the term is "Endothermic Reaction" means they Absorb heat, Hence the name "Absorption cooling unit) then the mixture travels down to the boiler where the burners (Gas or electric) cause it to seperate again and round and round we go.
If it is that hot perhaps a fan or 2 will help.. I added a pair of 4" computer fans I got cheap (less than a buck) blowing up and it does seem to help. You can also put 'em in the top vent sucking up and blowing OUT.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
