Old-Biscuit
Jun 25, 2017Explorer III
Fans use a t-stat that is attached to the condenser fins.
Based in fin temp the t-stat closes to start fan(s) and opens to stop fan(s)
Typical temps used are 130*F (close) and 115*F (open)----that is HOT
Other temp range t-stats are available.
As Chris stated........the more 'heat' that can be removed the more ammonia vapor can be condensed into liquid ......more liquid ammonia the colder the freezer and then more heat absorption left for food section.
Airflow.......its all about airflow (and how/where that airflow is directed)
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
