BFL13
Jun 25, 2017Explorer II
The installation instructions for the Dometic 7401L (smaller sort of RV fridge) include using a baffle below the upper fins so the cool air from the lower vent will pass through the fins on the way up to go out the upper vent.
In some RVs you have a wide space behind the fridge so the cooler air rises up right past the fins and out the roof vent without going through the fins. The baffle stops that.
In some cases a fan can help push/pull the cooler air up. Goodness knows how it can all work down there in Arizona right now! :( What "cool air" coming in the bottom vent?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
