Old-Biscuit
Jun 25, 2017Explorer III
happycamper002 wrote:
I'm referring to those who are advising installing fans. Of course you need to remove heat in the condenser portion of any cooling system. This heat that is absorbed at the evaporator end needs to be removed by fans but they are not located in the vents.
Go back and reread the other posts.
Norcold & Dometic have ventilation kits which include FANS and baffles for use in the outside compartment
Factory installed fans on fridges in slide outs are standard
Several aftermarket companies have fan kits for installation
This has been a routine occurrence for many years.......All of these companies have Teams of Lawyers
ARPC LLC fans for fridges
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
